Skip to main content
Skip to Main Content
Navigation
Chapter 4: Organizing Judges
Lesson 1: Planning the Judging Day
Learning Objectives:
  • Identify the points a judging schedule is built around: when the Event Partner needs the awards submissions, and when rankings are final.
  • Describe how to build a judging schedule backward from those points.
  • Determine how much time is needed to interview every team.
  • Determine how many Engineering Notebooks the remaining judge time allows to be scored.
  • Describe how to prioritize which notebooks are scored when more are submitted than can be scored.
  • Explain the tradeoffs between running notebook review and Team Interviews sequentially or in parallel.
Judging is your part of the event to organize. The Event Partner recruits the volunteers and tells you when they need your award decisions; everything between those two things is yours to plan. Most of that planning happens the morning of the event, from what you learn when you arrive.
Note: Schedules vary wildly from one event to another. There is not a perfect schedule that will work for every event. It is up to you as the Judge Advisor to work with your Event Partner to plan a judging schedule that fits that specific event. Use the guidance here to help you determine timing.
What You Learn on Arrival
Three things set the shape of the day you are organizing, and you find out all three on site:
  • When the Event Partner needs the awards submissions.
    • Ask for it directly, and ask whether that time already accounts for their verification before the ceremony. This is the deadline everything else works back from.
  • When rankings will be final.
    • Look at the match schedule. The Excellence Award requires teams to be in the top 40% of qualification rankings, overall skills rankings, and autonomous coding skillrankings, so it cannot be decided until all three are settled. Deliberations that start before then can finish every award except the one that depends on the rankings.
  • How many judges are actually present.
    • The Event Partner's volunteer list is a projection. Weather, traffic, sickness, and other events happen and may cause judges to cancel at the last minute. Count the people in the room, and build the plan on that number.
What a Judging Day Looks Like
Here is the shape of a sample event with twenty teams, drawn from a published agenda:
TimeWhat HappensWhat Judges Are Doing
Before 9:00amVolunteers arriveOrientation and modeling the rubrics
9:00amDoors open, teams check inNotebook review begins
10:30amFirst Qualification MatchNotebook review pauses or finishes, Interviews begin
1:00pmFinals/Elimination Matches BeginInterviews end and deliberations begin
2:00pmAwards CeremonyWatching the ceremony
Note: This timeline is an idealized scenario. You will likely need to adjust throughout the day to fit your schedule and that event’s timeline. For example, a VEX IQ day may run differently because Qualification Matches take longer, so they finish closer to the awards ceremony and the window for deliberations is much tighter. Later lessons cover how to keep judges on track.
Building the Schedule
Working Backward
Start at the submission deadline and move earlier:
  1. Deliberations end at the award submission deadline, with time before it to confirm each selected team meets every criterion.
  2. Deliberations should not begin before rankings are final, if possible. The gap between those two points is your deliberation window. Chapter 5 covers how to size and structure it.
  3. Interviews must be finished before deliberations begin. Tell judges that time — they cannot pace their day without it.
  4. Notebook review takes the morning, starting when teams check in.
Budgeting Team Interviews
Every team must have the opportunity to be interviewed. That makes interviews the activity you plan around, since notebook scoring is the one with flexibility in it.
Plan 15 minutes per team — about 10 minutes of conversation, plus time for the two judges to write their notes and score afterward.
Working it out is a matter of dividing teams among your pairs, then multiplying by 15. Let us walk through an example with an event including 20 teams and 6 judges.
  • 6 judges means you have 3 judging pairs.
  • 20 teams ÷ 3 pairs = 6-7 interviews per pair
  • 7 interviews per pair × 15 minutes per interview = 105 minutes for interviewing.
If you are working with a schedule like the one above, this would mean just under two hours dedicated to interviewing teams. Build in spare time wherever possible. Teams will be queuing, away from their pit, or mid-repair when a pair comes by, and each of those costs a return trip by the judges. Plan for about a quarter more time than the number suggests. In this example, that would be another 25-30 minutes.
When it does not fit, you have two options:
  • Shorten the time per team. 12 or 13 minutes still allows a real conversation. Below about 10, judges are cutting students off rather than scoring what they heard.
  • Start interviews earlier and run them alongside notebook review. This buys the most time, but can make the schedule harder to hold.
You cannot recruit more volunteers at eight in the morning, and you cannot move the ceremony. These two are what you have to work around.
Budgeting Notebook Review
Notebook review is the tightest activity of the day. Plan 5 to 10 minutes per notebook per judge, and use 10 when you work out your numbers. Every notebook is reviewed and scored by two judges separately, so each one uses 20 minutes of judge time.
To determine the number of Engineering Notebooks you can review, start by looking at the remaining judging time in your schedule. Continuing the example from above, with deliberations starting at 12:30pm and 2-2.5 hours needed for interviews, notebook review needs to happen between 9:00 and 10:00am.
  • 6 judges × 60 minutes of notebook time =  360 minutes of judge time
  • 10 minutes per judge × 2 judges per notebook = 20 minutes per notebook for judging
  • 360 minutes of notebook review ÷ 20 minutes of judging time = 18 notebooks
Use 10 minutes rather than 5. If judges move faster than that, you gain notebooks you had not counted on — a much better position than announcing a number you cannot reach.
With twenty teams submitting, you would score eighteen and have two left over. Those two can often be picked up in the spare time inside the interview block. If they cannot, that is a normal event, not a planning failure. In many cases, you will have more notebooks than can be reviewed and scored during the event timeline. In that scenario use the guidance below to determine which notebooks to review first.
When Notebook Review Happens
That hour of review time in the example above assumes judges get an hour to do nothing but read. Whether they do comes down to one question: can notebook review finish before interviews need to start?
When it can, judges do one thing at a time. Review gets a clean block, your two sets of numbers stay independent, and this is the arrangement to aim for. The typical day shown above works this way — review has the hour between doors opening and the first match, and any notebooks left over get picked up later.
When it cannot, judges move between the two activities and notebook scoring happens in the gaps between interviews. This is common, and it works, but those gaps are much easier to lose than a scheduled hour. Estimate them conservatively and expect notebook review to be what slips.
Work out your interview time first, and this decides itself. If interviews fit between the first match and the end of qualifications, review keeps its own block.
Which Notebooks Get Scored
Sort the pile as notebooks come in, and put the ones that arrived with a Season Summary first.
The Season Summary is how a team tells judges where to look. A notebook that has one can be thoroughly scored in 10 minutes, because the team has already pointed to the entries behind each highlight. A notebook without one asks a judge to find the substance themselves, and that does not fit in 10 minutes.
  1. Notebooks submitted with a Season Summary are scored first.
  2. Notebooks submitted without one are scored if time remains.
Sorting only matters when you cannot get to the whole pile of submitted notebooks. Do this sort yourself as the Judge Advisor. You are checking whether a summary is present, not reading it or forming a view of the notebook, so it keeps you clear of the evaluation. Tell judges how you sorted when you introduce the activity, so nobody assumes notebooks went missing.
