Skip to main content
Skip to Main Content
Navigation
Chapter 4: Organizing Judges
Lesson 2: Facilitating Engineering Notebook Review
Learning Objectives:
  • Identify how to introduce judges to Engineering Notebook review.
  • Explain why modeling scoring with the rubric can help judges stay consistent within an event.
  • Identify that at least two judges need to review and score each submitted Engineering Notebook.
  • Identify strategies to keep judges on time during the review process, and adjust if necessary.
  • Identify additional Judge Advisor tasks that can take place while judges are reviewing Engineering Notebooks.
Lesson 1 gave you the numbers: how many notebooks can be scored, how long each one gets, and which ones go first. This lesson is about the review block itself — getting judges started, keeping them consistent, and holding the plan you built.
Notebook review is usually the first judging activity of the day and the one least affected by what is happening elsewhere at the event. Teams submit their notebooks at check-in or ahead of time, and nothing depends on what a team is doing at the event.
Introducing Notebook Review
Before judges open any notebook, give them a short orientation of the review process. You do not have to teach the rubric from scratch — you are giving a group with uneven preparation a shared starting point. Be sure you have rubrics on hand for everyone to look at while you talk. A few minutes usually covers it:
  • What are they reading for? Evidence of the Engineering Design Process: the problem a team defined, what it tried, what it learned, what it improved. Not polish, length, or handwriting.
  • How is the rubric organized? Five sections, sixteen criteria, each row scored 1 (Beginning) to 4 (Exemplary). Every row gets a score, so totals run from 16 to 64.
  • Where should they begin with each notebook? Read the accompanying Season Summary first. Then follow its pointers into the specific entries behind each highlight.
  • How long can they spend on each notebook? Give judges a number and tell them it applies to every notebook. Remind them that they are not required to read the entire notebook in that time. They are looking to gather enough information to score with the rubric.
  • What is the procedure for review? At least two judges will review each notebook independently. They will then compare their scores to ensure consensus.
  • What happens to the scores? All scores stay within the judging team. Keep rubrics together with the notebooks, so you have them easily available for deliberations later.
  • What should they do if they have questions? Say explicitly that they should ask questions to you or discuss their review with other judges. A judge who is unsure about a row and does not ask will guess, and guesses are where consistency falters.
As judges bring up questions, remind them that they are not investigators. Finding problems is not part of their job. If something does not add up, tell them to bring that concern to you rather than letting the concern affect a score or a later interaction with a team.
Modeling Scoring with the Rubric
Judges who read the same rubric row may not read it the same way initially. One judge's Proficient is another judge's Exemplary until the two of them have said out loud what they are looking at. Scoring at least one criterion together during your orientation, before anyone starts reviewing in earnest, is the fastest way to close that gap.
It does not have to take long:
  1. Put one criterion in front of the group — one with clear divisions, such as Criteria and constraints are defined or Brainstorming is documented works well as a starting point.
  2. Show one notebook entry that speaks to it.
  3. Have everyone choose a score on their own, then say what they chose.
  4. Where the answers differ, ask each judge what they based their score on. Then read the level descriptions together and settle on the score the description actually supports.
  5. Repeat these steps with another row of the rubric — one with a fine line between levels, such as Test procedures are defined or Decisions are explained with evidence works well here.
The goal is not just agreement on that one entry. It is that every judge hears how the others reason before they scatter to their own piles. A group that has done this exercise together tends to score more alike all day, and judges who were meeting the rubric for the first time have a reference point for what the levels mean in practice.
Two Judges per Notebook
Have at least two judges score each notebook. They do this separately, each filling out their own rubric, without discussing the notebook first. Two independent reads are what make a ranking hold up — a single reader's score reflects a single reader, and two judges who talked before scoring produce one opinion recorded twice.
Once both judges have scored a notebook, they should compare their scores. As judges review they should:
  • Talk through any criterion where the two scores differ by more than one level.
  • Compare rather than average. Averaging hides the disagreement instead of resolving it, and one judge may have found evidence the other did not.
Two people sit at a table each with laptops open in front of them. The man on the left looks over at the screen of the womans laptop as she shows him something on the screen.
Keeping Review on Time
As judges are actively engaged with the notebooks, your role is to make sure that they are staying on task and working consistently. Plan to check in with judges through the review block, and tell them when to expect you so the check-ins do not feel like high pressure moments.
  • After each pair's first notebook. Ask how the time felt. This is an easy chance to adjust before the pace is set for the day.
  • At the halfway point. Count what is left against the time remaining, and adjust accordingly.
If your review block runs longer than an hour, add a third check-in with about thirty minutes left — late enough to know where you stand, early enough to redistribute.
Between checkpoints, keep an eye and ear out so you can identify judge(s) who need more support. A few things can tell you a pair is in trouble:
  • Still on their first or second notebook well past the time limit.
  • Finishing far under the time limit, which usually means rows are being scored quickly rather than read thoughtfully.
  • Scores from one pair clustering noticeably higher or lower than the rest of the room.
If this happens, be kind and honest with the judge and get them back on track. A quick corrective conversation can help them stay engaged in the day, rather than feeling overwhelmed or unsure moving forward.
If you need to adjust more broadly, you have a few options, like:
  • Redistribute the remaining notebooks to judges who are ahead.
  • Shorten the time frame for what is left — and tell the whole room at once, so the change applies evenly rather than only to the judges you spoke to.
  • Reduce double-reading for the notebooks in your second group (the ones that came in without a Season Summary) so every notebook in the first group still gets two independent scores.
Announce every change to everyone. A limit that quietly varies by judge is worse than a limit that was too short to begin with.
While Judges Are Reviewing
Once judges are set up and working effectively as a group, notebook review can be a stretch of the day where they need the least from you. Be sure that you are always staying in earshot of judges as they work, so you know what is happening and how notebook review is progressing. Don’t try to multitask at the expense of facilitating the review process.
If you do have time to multitask, notebook review is a good time to:
  • Confirm which teams submitted a notebook and which did not, and collect additional notebooks from check-in as needed.
  • Build interview assignments, and check them against the conflicts of interest judges disclosed.
  • Note any teams with accommodations, so you can brief the assigned judge pair before interviews start.
  • Start putting scored notebooks in rank order as rubrics come back, so the pile is ready for deliberations.
Be mindful that a big part of your job as Judge Advisor is being able to adjust and be flexible to ensure that all judging activities happen effectively throughout the day. Ensuring that Engineering Notebook reviews start the day off on the right foot can help set the rest of your day up for success.
